Hi,
in my environment it is very often necessary to change sharpness depending on the selected image aspect. 4:3 content needs a sharpness level of 1, lbx because of zoom one of 2 or 3 and anamorphic 0 or 1 to look fine. As the selection of the sharpness is hidden deep inside the menu and sharpness isn't stored together with the selected aspect like with image zoom, this is always very time consuming because of a lot of key presses.
To improve this I would like to propose two changes to lumagen:
1. sharpness should be settable per aspect or for all aspects
2. have some short cut key to scan through the sharpness settings
The first change should be easy to make because the same functionality is already available for image zoom.
The second change could be implemented by using an unused number key. Pressing this key repeatably could scan through the values 0-3 and wrap. This should be a temporary setting. Changing aspect should go back to the stored setting.
What do you think about this?
Cheers,
Emil
Cheers,
Emil
