Status
Not open for further replies.
1 - 2 of 2 Posts
Lumagen Vision PAL->NTSC question...
Ok I have KDF-60WF655 which I wan to move with me in Europe.
But the problem is that this TV is NTSC only.
The solution is to buy Lumagen Vision or Vision DVI... (Anyone have one for sell?).
What kind of picture quality should I expect? Will be there judder or other defects??
The COMPONENT or DVI inputs/outputs are they transmitting ntsc/pal/secam signal or they transmit something independent from ntsc/pal/secam?? I mean if I output pal from the component to the component of my ntsc TV will the TV accept the signal?
The Lumagen Vision & VisionDVI are for use with ED/HD capable displays---they do not output SD (NTSC or PAL) and only take those signals as inputs. If you really mean can it convert PAL at 50 Hz to and output ED/HD resolution at 60 Hz then, yes they can do that. If you're watching closely and there is some kind of smooth motion going on then occasionally you may notice a small amount of judder with this type of conversion.
1 - 2 of 2 Posts
Status
