I posted this in another thread responding to someone who knew nothing about Lutron. Thought it might be also useful here.
Lutron is very different than any other company in the space. They are the 800-lb gorilla in high end lighting with the patents and product line across many different markets, segments, all across the world. As for them exiting the residential market, their founder invented the first solid state dimmer in 1959, along with Lutron releasing the first IR controlled dimmer, first linear slide dimmer, first whole-home lighting control system, first customizable dimming system for different light sources, and the first 2-Way RF whole home lighting control system, etc etc....
Every company making RF switches is paying royalties to Lutron if they use things like polling. So yea, don't lump them in with other random companies that have withdrawn from the residential market or failed. Put some respect on their name, as they say.
They are also family owned privately held company, which allows for more longterm decision making. Anything is possible, but there is zero evidence based on 59 years of Lutron as a company to have any concerns about them suddenly exiting the residential space.
So what are you getting for your money if you buy a Lutron system? Let me list a few that matter to me personally:
Reliability: Lutron has a ~60 year track record of best in class reliability. It's what they built their company on and virtually nobody with actual experience with Lutron products will dispute that. There are plenty of 20-30+ year old systems still running perfectly and they try to keep parts available for obsolete systems for 10-15 years. The latency is much lower than Z-Wave and when properly installed, commands are received and executed 100% of the time. Clear Connect uses a dedicated and heavily regulated frequency, the others do not. It's the most robust and reliable wireless system there is, period. Any disputing of this fact is just silly and disconnected from 20+ years of evidence and tens of thousands of reviews from end users of competing products.
No mesh network needed, no hops, no rebuilds, no firmware updates to fix bugs from the 100s of manufacturers trying to work with a standard that has lots of optional features and not every company properly implements. I (and apparently many others according to reviews) was lucky to get even 1-2 years from most of my Zwave switches. My Z-Wave hub recently got an update with like 80 bug fixes for all the devices from different manufacturers that weren't working as they should according to the spec.
An open system with 500 different parties will never be more reliable than a well-designed and implemented closed ecosystem like Lutron where they control the design, manufacturing, and testing of all software and hardware to work perfectly together. That's just a simple fact.
Customer support: Lutron has a ~60 year track record of exceptional customer and technical support: You want to speak to an actual engineer on the phone? Sure, no problem. Even their level one tech support people know more about their products than just about any other company I've dealt with. This is especially impressive for a company with thousands of employees. They will send you any part or product you need right away if there's even a question about whether or not it's functioning correctly. No RMA forms to fill out, no waiting to receive the product back, no credit card hold, etc.....
Ease of use: When you buy a Lutron product, you will not be a beta tester. The product will have already been thoroughly tested and should function as expected. Just plug and play, no research or forums needed. There won't be any 700 series Z-Wave style "fun" that takes months of updates to resolve.
Quality: You get high quality construction and 100% consistent finish with every product. This is a pretty basic standard that many companies fail to meet.
Picos, Picos, Picos: There is no other product even close to the size, versatility, reliability, and battery life. There's 30+ models to choice from with all the engraving and customizable options you could ever want. You can get them with a nightlight, control Sonos, shades, lights, appliances, etc. Use them on a tabletop, or add them to the an existing switch gang without cutting any holes, or stick them on any surface, move them around as often as you want. All with 10 years battery life and the same reliability as the rest of the system.
This is a benefit of designing a system with hub and spoke topography that can use both 1-way and 2-way RF devices.
User interaction: The switches and keypads are designed with attention to all the important details, like tactile feel. The Maestro style button has the best tactile feel of any switch I've tried. The SeeTouch keypads also have such a nice feeling when pressing the buttons with great tactile feedback. The buttons are rounded so it's easy to press the button you want and the engraving is angled upwards so it's much easier to read than an engraved flat button. You can also have spacing in between the buttons for areas were you need to press it quickly while you're walking. Little details like that make the all the difference compared to other options.
Custom engraving and backlight: There is nothing easier to use then keypads with engraved and backlit buttons, period. No previous knowledge of the system is required, no flipping the whole bank of switches trying to find the light you want. You see a button with the light icon and "Kitchen", you know exactly what you're turning on.
I've seen so many videos of people showing off their HA systems with all these banks of switches and to trigger a scene/action you have to triple tap the top or bottom of one of these switches (that all look the same) while touching the top of your head and standing on one leg at the same time. That's great if you live alone or want to take the time to train your family, but don't try to tell me it's just as easy as pressing a single button with a clear backlit label.
Not to mention how much easier it is to use a backlit keypad at night.
The TableTop keypads are another super useful and unique product. I have one by each bed, and also in the living room and theater to control the lights, shades, and scenes. They're engraved and backlit as well along with battery or plug in power. Very flexible.
Eliminate wall ache: Using keypads, you can eliminate large banks of switches everywhere. I plan to use hybrid keypads everywhere there would be more than one switch and place the excess dimmers/switches in a network room. That's not for everyone of course, but it's perfect for me. Even a simple room like a bedroom would need a 4-gang of switches: Lights, lamps, fan, shades. So I can eliminate three of those. It's even more useful for rooms like kitchens that have multiple layers of lights.
Options: Over 40 color options for switches/outlets/wall-plates. No other company offering Z-Wave or the like can even come close to that.
Interoperability: Lutron has published a very clear and easy to implement protocol so even though it's a closed system, it can be integrated with virtually any HA controller. Phantom keypads are a nice feature as well.
Consistency in the little details: All the shades raise and lower at the same speeds, large lighting events don't popcorn.
Shades: The Lutron shades are the quietest and have the best battery life on the market. They've also been the most reliable in my experience. The batteries last 3-5 years and the warranty is up to 7 years. They integrate perfectly with the rest of the lutron controls and system. No third party hub needed.
I could go on and on, but since I've already made this post way to long, I'll stop.
So yea, you're paying a lot more, but you're getting a lot more options, reliability, ease of use, aesthetics and more. It will not be worth it to everyone, but saying that there's no value in it is just ignorant.
