Status
Not open for further replies.
1 - 12 of 12 Posts
· Registered
Discussion Starter · #5 ·
the RMAA results I've got here are a lil inflated. I kinda played around with the input/output levels until I found a setting that was optimum
(I later realised the input output levels should match 0/-6dB according to the manual whereas mine when tested were about -6/-14dB)
anyway, at 16/44 and @input levels of -6dB/-14dB approximately (input 1/2 in rmaa) the Revo had:
Revo 16/44
Frequency response (from 40 Hz to 15 kHz), dB:+0.13, -0.06
Noise level, dB (A): -98.2
Dynamic range, dB (A): 95.9
THD, %: 0.0009
IMD, %:0.089
Stereo crosstalk, dB:-93.4
at the 0/-6 level, it was somewhat closer to the other Revo RMAA results we've seen.
here's a big pic of the card below
(EDIT: RMAA results posted above are probably inaccurate cos of the non-standard input levels used. but it was just fun to see numbers higher than the LynxTwo on my humble Revo
· Registered
Originally posted by rickcfer
Cliff ?
Just checked with M Audio about the rev numbers and was informed that the design has not changed.
They are using the rev number to track the manufacturing runs. Rev 3 was the third run for Revo.
· Registered
Originally posted by ablaze
btw, escaflowne, do I know you? whats with all the ;)s? :D
It's just a nice way of greeting
It's always good to throw a smile .... here and then
Anyway I did read dome of you post at hardware zone tough...but I didnt post anything there....just browsing ;) I'm from Malaysia btw.
Thanks for the pics ablaze... I only noticed two chages from the pics you sent...one is the m logo on the rev 2 was replaced with an m-audio logo on rev 3 ....nice change
And the other thing is the m-tek chip has some different numbers than the rev 2... Not sure what this chip is for though
But since Cliff already checked with m-audio I highly doubt there was any design changes
And thanks Cliff for checking with m-audio
· Registered
"And the other thing is the m-tek chip has some different numbers than the rev 2... Not sure what this chip is for though"
Probably just different production date numbers. It is a small "Digital Audio Data" transformer, probably used to drive the S/PDIF output.
· Registered
Odd, that should be done with a date code. A different Rev number implies, well a different revision.
· Registered
Not with M Audio. They do very odd things with codes and rev numbers.
1 - 12 of 12 Posts
Status
