Problem yes, big problem could be. Solution, repair the amp, replace the amp, get a new sub.
See if parts express has a amp rated at the same power, if it does, you could use that, with a hole drilled in the cabinet for the wires from the new amp, with some sealant caulk to make sure there are no air leaks, you could be as good as new-old.
