Macs, DVD & digital sound: surprisingly few options?
8216 Views 75 Replies 22 Participants Last post by  secretagent86
There's some discussion of this on the catch-all Mac mini as HTPC thread, I thought it might be valuable to pull this one aspect out for further examination, to clearly lay out what's working for members, what isn't and why when it comes to dvd's and surround sound, because I suspect this one aspect of the mini likely will frustrate more people than anything else--not cracking open the case, not the single RAM slot, not the 40/80GB or 5400/4200rpm hard drive options, not the supposedly limited number of firewire or usb ports, all of which are actually easily overcome. Note also I'm not even getting into the HDTV-related aspects of the mini which may stretch the capabilities of these minis beyond where they can go. Just surround sound from a standard dvd, something even most cheap standalone dvd players can pass to a receiver to decode. I wouldn't have to jump through too many hoops to get it, would I?
Boy, was I wrong.
G5 PowerMac or 17" PB owners have digital out built in, so there's no problem for them. They can go into Apple dvd player preferences > disc setup > audio ouput > then select digital out instead of "system sound ouput." On other less expensive systems, like the iBooks, the 12" and 15" G4 Powerbooks, and the Mac mini--Apple's DVD Player preferences panel in current version 4.0 doesn't give you another option--we're stuck on "system sound output." So far so good, but little did I realize what inherent limitations lay ahead for me.
From what I knew of Macs and OS X, I knew we could stream iTunes audio through an Airport Express minijack-optical out port into a stereo receiver, but that's of no help (yet) for anything other than iTunes. I knew we could plug a minijack cable into our headphone out for audio out and divert sound output away from our internal speakers, so I'd have been willing to bet we had other output options even at this price point, as long as we were willing to buy a third-party add-on. As long as the DVD player software recognized "system sound ouput" and as long as OS X had a built-in way to detect and select a different system sound output, we'd clearly be fine. That's how Macs work, plug something in via firewire or usb and bingo, it's recognized, and it just works. In theory.
You've probably read about all sorts of Mac-compatible USB and firewire add-on sound devices and perhaps even assumed these will allow you to pass the Dolby digital or DTS audio track of a dvd out through a USB port and into your receiver through digital coax or optical cables. Seems rudimentary, I know I thought so. Plug in one of these sub-$100 USB audio devices, go to System Preferences, under Audio, surely it would show up automatically and allow you to select it for system sound output rather than the internal speakers. Would it have been nice if Apple somehow had built this digital audio pass-through capability into the mini? Sure, but I appreciate the price being kept low and I would have bought a mini anyway. I went in with my eyes open. My real surprise now, though, after looking around a bit, is how few options we actually have at the moment in terms of DD and DTS--even if we're willing to spend more money--and just how crippled Apple's DVD player turns out to be. Guess my eyes weren't that open.
What do I mean? To get started, I plugged in a USB digital audio pass-through device--one that received rave reviews in the PC community and was readily available locally from CompUSA--something called the Xitel Pro HiFi Link, $99 list. It had both optical and digital coax out, a plus in my book even though I have 3 coax and 3 optical ports on my receiver; the product also included runs of high quality coax, rca and optical cables which I'd also put to use, a USB cable, it had a nice aluminum-look surface--and a quick check of their website pre-purchase indicated it worked with OS X plug and play. The other options I considered were the M-audio USB products mentioned elsewhere on AVS by Kevin and Bruin, but those had two things against them in my book: M-audio seemed to require drivers, which might mean trouble down the road with future OS updates or with Tiger, and they weren't available locally that I could tell--not in BB, CC, Staples, etc. So I went with the Xitel, plugged the thing in to one of the USB mini ports, connected via digital coax to my Harmon Kardon receiver, went to the mini's System Preferences > Sound > and a USB audio device automatically showed up. I selected it, popped in a dvd, and bingo, very clean sound, prisitine even, but still "just" stereo PCM sound, showing up as Dolby ProLogic II on my HK. No amount of configuring DVD Player or System Preferences allowed DD or DTS through on multiple dvds. It was always PCM stereo. Turns out, after a call to Applecare tech support, that Apple software limits it to PCM stereo on the mini.
Same thing using the Xitel and an alternative software-based dvd player for the Mac--VLC. Even when you select VLC > Preferences > Audio > and tell it to "use the S/PDIF audio output when available" it seems PCM is all that's made "available" by 10.3.8 and the mini via USB. Unless I'm missing something about VLC and the mini--I find VLC confusing and buggy even on a good day--which is entirely likely. So anyone with VLC, chime in here.
So, I'm now wondering, is it that M-audio has spent the time and expense to write drivers to insert their product into the Apple software that specifically and exclusively allows their products to circumvent Apple's inherent limitations?
What has everyone else tried? Any surround sound success? It seems the only confirmed reports of digital pass through success I've found are with these M-audio USB products--the "Transit," the "Sonica Theater" and the older/hard-to-find "Sonica USB"--passing Dolby Digital surround and DTS to a receiver when playing a dvd in a mini. I believe on AVS Bruin (Ben) and Kevin have used these and gotten pass through--if so, guys, how'd you have to configure it? Do these products work with both Apple DVD player and VLC? Do all three pass DD 5.1 to 7.1 and DTS? Did you load the most current M-audio drivers and find that it then just works with 10.3.8 when you select USB audio device instead of internal speakers? Any bugs, hiccups, dropouts?
Some other questions, if anyone cares to weigh in:
1) Historically, how was anyone playing dvd's in their older (then-very-expensive) Powerbooks, displaying the video on an external monitor (easy) and passing DD or DTS to their receivers? Has everyone just been playing analog or PCM stereo audio out through their minijack? I had never thought about this before because like most on AVS I have good upscaling standalone dvd players. It's only the form factor of the mini, and its potential in a home theater, which opened this avenue for me...and made me realize I never tried to get DD or DTS out of my powerbooks.
2) Beside the G5's and 17" PB, can older G4 PowerMacs be modified to pass digital surround through to a receiver, I'm guessing yes via pci card or bus? Is the answer yes? If so, how have most done it?
3) Getting back to the mini, has anyone successfully used a USB product beside an M-audio and passed DD or DTS through? Did they work plug and play or require proprietary drivers? The Xitel cannot with Apple's DVD player and I couldn't seem to configure VLC to allow it with the mini.
4) Has anyone successfully configured any alternative software-based dvd player like VLC to pass DD or DTS audio a) by itself or b) with an external device? If so, which ones and how?
5) Are there affordable firewire devices which we should be giving consideration to which work any better with Macs than the USB ones already mentioned?
Or, is our ONLY affordable option right now the M-audio? And if so, do reports like this give you pause:
http://www.macosxhints.com/article.p...40514125451790
(Apologies for length. Edited to add link.)
See less See more
Status
Not open for further replies.
1 - 20 of 76 Posts
I'm currently running 10.3.8 w/ the latest M-Audio drivers. DD works when selecting the digital out in the DVD Player's preferences. I haven't tried DTS for quite some time (though I believe it worked).
Generally though I have my system set up to run pro-logic out to the receiver as that is the only way I can also have stereo out to the rest of my household distribution. I wish that the sonica would simultaneously output DD and analog (or perhaps the OS) but that is unfortunately (for me) not the case.
Kevin
See less See more
Thank you Kevin, it's actually been your participation on threads (here and elsewhere) which prompted me to think about this more. So we have confirmation with a mini, 10.3.8, the M-audio Sonica USB and the latest M-audio driver for it (1.0.3f1) that when you open Apple's dvd player > preferences > audio output > Kevin sees a second option beside "system sound output" and gets true DD passed through to his receiver. Anyone else?
Kevin--have you by chance tested whether the Sonica USB and its drivers allow VLC to also detect that it is an optical S/PDIF audio output device and pass DD surround to your receiver?
Has anyone tried the Edirol and, if so, to what degree of success have you had playing a dvd and passing AC-3 or DTS sound?
http://www.edirol.com/products/info/ua1d.html
Yes, VLC also see's the optional sound output (at least it did on 10.3.5 or so when I last used it).
This is running on a Dual 1.44 Ghz G4, not a mac-mini btw.
Kevin
Prior to 10.3.8 (10.3.7) I had Dolby Dgital and DTS pass through my M-Audio Sonica theater, without any real problems. Now after 10.8 I can’t get DTS to pass, I get this choppy stuttering 'noise'.
Highly frustrated.
Kevin, thanks. Thanks also B for confirming you at least get discrete Dolby surround, like 5.1, to pass using the Sonica Theater and the mini. I missed that you already reported on your blog that DTS was broken by 10.3.8--sorry. Are you running the 1.5.7f1 driver for the Sonica Theater from October 2003? Have you tried contacting M-audio for "support" and how responsive were they? The web is littered with user issues involving these products--yet these seem to be the only ones capable of passing more than PCM.
These reports are helpful because I'm guessing there are some folks out there who think they're getting surround with these type of devices but who are really just passing PCM to their receivers, which in turn is processed and sent out to their surround speaker system via Dolby ProLogic. The Mac gamers have their own unique multi-channel issues, and seem to have been talking about this for a long time:
http://www.insidemacgames.com/forum/...hp?showforum=3
But they, in the main, are on G5's and have digital audio out capability built in!
I wish that my cynical sense of this issue and these consumer USB audio devices was more developed than this: one company, M-audio, got into a process of writing additional drivers to work with OS X, to pass DTS and Dolby surround, requiring a departure from the generic audio platform which most other manufacturers chose not to do. That's why these other devices like the otherwise excellent Xitel only pass PCM. But both of these decisions come at a cost, for M-audio it causes issues with driver maintenance and also compatibility; for Xitel the cost is lack of relevance for the Mac platform until their development team does something or Apple opens things up.
It's still amazing to me that this isn't all very easy to implement right now, that Apple and third party vendors didn't realize sending raw DTS and AC3 down the USB was going to be a very real, very natural requirement of users planning to play dvds, and that a least a significant number of them were going to integrate their computers more into their home entertainment environment.
See less See more
It sounds like the Xitel device is not fully supported by MacOS X. I ran into similar problems when attempting to use another PC audio device, the SoundBlaster Audigy NX, with MacOS. It shows up in the audio preferences without the need for any device drivers or other system modifications. But, it only supports stereo PCM, none of the digital in/outputs are seen.
At this point, I will be focusing on products that are verified to work in MacOS, rather than trying to get my PC devices working. I have seen quite a few reports of audio devices supported DD under MacOS. I'll be picking one of those up, rather than monkeying around with the SoundBlaster any more.
Our product uicmate 101s
does not required driver simply plug and play as it should. But as mention in earlier post it does not support Apple DVD player because it does not support third party digital pass thru just yet.
I have test on VLC 0.7.2 and 0.8.1 without any problem. The only problem I have so far is VLC seems to channel the center speaker to the left side on our newest 7.1 channel product. So I only hear the dialog on the left side. This does not happen on the 101s (5.1) thought.
my latest test is done on KLH R5100 receiver. without any thing connect to one end of the optical cable the LED panel display 3 speakers. With our device plug in USB of my 15 tibook and the reciever it show 6 speakers indicating its receiving 5.1 channel digital sound signals.
I will continue to test on various receiver as I can get my hand on them.
Mark
See less See more
That's the question tji--but I don't think it is a matter of a particular device like the Xitel not being "fully" supported by OS X--I think it is more that NO device like it is supported by OS X and Apple's DVD player when it comes to passing 5.1 or DTS. That doesn't seem to be supported unless you have a G5 or 17" Powerbook.
In the case of Xitel, they are very up front about this--they don't promote the Pro HiFi-Link as being Mac compatible, there's nothing about Mac OS, iTunes or AAC compatibility on the box, even though I can verify it operates perfectly fine for PCM audio and it contains a user manual with a Mac installation section, which is un-necessary in 10.3 anyway. Plug it in, play a dvd, it passes PCM only because Apple DVD software doesn't seem to support 5.1 digital pass through natively down the USB. That's what prevents the Pro HiFi-Link from being able to transfer 5.1 Dolby Digital and DTS Surround Sound from DVD titles because it only receives a stereo signal from Dolby content, and I can't get it to receive or pass anything from DTS . My guess is that that Edirol product I linked to earlier--the UA-1D--which comes with no drivers, operates plug and play with Macs and is also likely based on the same cross-platform USB standard as the Xitel--will also not pass DD/DTS when playing a dvd. Which is a shame, Mac-wise, since in all other regards the Xitel Pro HiFi-Link (and presumably the Edirol) functions exactly the same on the Mac as it does on the PC - ie totally compatible with all streaming, Internet radio and downloaded music. In to have more options and real choice, it seems we have to hope that when Apple implements 5.1 audio data down the USB, the Xitel-type units will then most likely be able to do DTS and Dolby Digital as well.
Another possibility, albeit more expensive, is another more sophisticated Edirol USB bus-powered audio interface, the UA-3FX, I think it goes for $200, has digital optical in and out but unlike the UA-1D comes with its own drivers for OS X. If there is a musician amongst us I'd love to hear if this particular device passes 5.1 or DTS when playing a dvd:
http://www.edirol.com/products/info/ua3fx.html
I'd be interested to see what else you turn up, tji, beside the M-audio.
See less See more
Didn't Kevin already confirm that the M-Audio was working with 10.3.8?
I have seen reports of the "Philips PSC805" working with OS X, and the Griffin Firewave is made for Mac.
I have seen a report of the SIIG USB SoundWave optical 5.1 ( http://www.siig.com/product.asp?pid=28 ) working with MacOS and DD5.1, even though it doesn't claim Mac support on their www site.
Also, last time I was at my local "Fry's Electronics", I saw an audio device in the Mac section for $50. It included S/PDIF input and output, and it had the MacOS X logo on the box.. a good sign for Mac usage. http://www.adstech.com/products/RDX-...sp?pid=RDX-150
As you mentioned, the Edirol products might be good options too, since they claim MacOS support.. http://www.edirol.com/products/info/ua1d.html
But, at this point I would try to buy from a local store so that I could return it if it turned out to only have partial MacOS support (i.e. Stereo PCM support vs. digital pass-through ). Hopefully, as more people try them, we can get full reports on what capabilities work on which system, and with which software packages.
See less See more
Chiming in... and very much interested in setting up a homewide Mac DVD server: My setup is as follows:
FAMILY ROOM
50" Pioneer HD Plasma
Integra 8.4 Receiver
5.1 Surround Speakers system
What I want to do is serve DVD's off my Dual 2.5 G5 located in my home office (upstairs) to the wired network around the house. Computers plugged into the network in each room should have no problem viewing VIDEO_TS files off the G5 with the soon-to-be digitized DVD library (working on a two terabyte solution).
However, I don't have a computer hooked up to the Plasma in the family room, although I have a ethernet hookup in the equipment cabinet. I'm not sure I want to go the Mac Mini route for the family room (too much configuration, extra set up, cables, space issues, keyboard, mouse, USB-dongles and whatnot). I was wondering if I wouldn't be better off using something like EyeHome (from elgato) to access the files off the network. I'm really torn on what way to go.
The questions (related to the surround sound discussion) are
a) will the EyeHome pick up the multi-channel audio (whether DD or DTS) from the VIDEO_TS folders on my hard drive and pass it through to my receiver? Couldn't find any conclusive answer to this on their website or on the web.
b) Is a standard ethernet network fast enough to handle DVD audio / video?
c) Does anyone have any experience with the EyeHome and home theater setups, or other solution?
d) Am I better off getting the Mac Mini (+ added cabling, extra memory, USB optical out, etc) or just getting the relatively inexpensive EyeHome or some other solution?
Thanks, in advance for your thoughts,
See less See more
I can verify it was working for EyeTV, I'm not sure I've actually watched a DVD in 5.1 since upgrading to 10.3.8...
Kevin
Dear Chefklc
a bit late here, so sorry, and some have already answered. A quick review of my setup:
Mac mini 1.42Ghz, 10.3.7
Sonica USB (original with latest drivers) connected via toslink optical to a
Meridian 562V/565 surround sound system (my version supports AC-3, but not DTS)
I have also tested the Sonica with a Powerbook G4 667 (DVI model)
Using both DVD player or VLC player, the Meridian display confirms it is getting an AC-3 input. Sometimes however, I have to make sure the DVD sound has been selected from the DVD menu properly.
I am also able to use iTunes correctly, though my Meridian initially tries to output it as THX. When I change the setting on Meridian to stereo or super stereo etc, it sounds very good indeed. Interestingly, I am also able to select an airport express output in iTunes to one set of speakers (eg second pair off the Meridian) WHILE watching a DVD in AC-3 via the Sonica. The Mac mini handles this just fine.
The Sonica is not without problems however. Sometimes it forgets it's there (sleep is ok, but either re-starts or changing the USB port can cause problems). I also get some annoying sounds when the signal stops (eg when moving from DVD menu to play). These are similar to the sound I get from iTunes/Airtunes/Optical when I switch tracks. Also, I have had situations where the Sonica seems to go back to doing it's own thing - adding "TruSurround" etc. For the last week it has been stable - output all correct, though I have not moved it or restarted the machine (used sleep all the time).
To answer specific questions:
I have used the Sonica in my G4 Powerbook. Seems to be ok with similar issues noted above.
Some G4 Powermacs had digital out I think. But anything that has a USB port should work.
No experience. I tried the Sonica because it was cheap (presumably old stock), so less to lose. I was also not going to wait on the Griffin, because it didn't seem like the specs were sorted (and they seem disappointing)
As said above, VLC seems to play AC-3 via the Sonica USB. But like others, I don't use VLC - it gives me lots of errors, and doesn't seem to select chapters properly. I have found the video out from Apple's DVDplayer BETTER than the VLC and certainly not worse (not sure why)
The Griffin mentioned elsewhere seems a non-starter for this purpose. I think we may have to wait for Tiger to have some more options (and I HAVE to believe these will be forthcoming).
Thanks for your efforts. This is a very complex topic which I tried to understand before shelling out my $50 or so for the Sonica! It is vital to our enjoyment, and we need to make sure it figures higher on apple's priorities and that of some third party suppliers.
Ian
See less See more
Ian--agreed the Griffin Firewave seems poised to become the most highly anticipated non-starter for home theater types, given its lack of digital coax or optical. I'm not sure how three 3.5mm stereo minijacks helps us. Their product language seems carefully crafted, vague if not dubious. Still, I'll have an open mind until someone actually gets their hands on one.
The wildcard in your setup (for me) seems to be the Meridian, something I'm unfamiliar with--is that a receiver? is that doing something as far as receiving and then processing that signal, say, that my Harman Kardon receiver can't? Apologies for ignorance. But otherwise, assuming the Meridian is doing nothing accept receiving optical in, thanks for confirming that you are 1) using a mini AND 2) indeed getting legitimate AC-3 Dolby surround passthrough--using that M-audio device--and until we collect a few more reports I'm concluding it is because of their sometimes-finicky drivers.
We've yet to have a single report of successful AC-3 passthrough with anything other than the M-audio. I, too, hope the rumbles that there will be a complete overhaul of the audio subsystem in Tiger pan out in our favor.
tji--thanks much--can you link to the SIIG report you came across?
My guess, looking at all the other products you mentioned, is that Edirol UA-1D will only pass PCM just like the Xitel, it's based on the same generic USB criteria and doesn't involve drivers of its own--so count on plug and play with Macs but PCM passthrough only, not AC-3.
The ADS RDX-150 seems a weak bet, no apparent digital coax or optical, and as a result likely limited to PCM stereo. Where did you see confirmation it claimed S/PDIF? I couldn't find an image of the back panel.
The SIIG appears to be in the same boat as the Firewave with three "interface ports" which are likely RCA--it talks about providing its own "Q-space surround effects," which might appeal to gamers who have self-powered speakers, but how is it gonna give us AC-3 or DTS without any digital coax or optical out?
I'm holding out some hope for the other Edirol product I linked to because additional software and drivers are involved--but tech support at Edirol can't confirm AC-3 passthrough on a Mac with 10.3.8 and Apple DVD Player. FYI--Edirol products are available locally but they are not in consumer electronic channels--you have to look for them in music stores.
See less See more
chefklc
Sorry, should have clarified. The Meridian equipment is essentially a Pre-amp with video switching (the 562V) and a Digital Surround Sound processor (565). In essence it's equivalent to a Home Theater Receiver - Meridian's website is http://www.meridian-audio.com . Meridian has been at the forefront of digital hi-fi - for instance keeping the signal digital right through to digital active speakers such as the DSP5000/6000 series.
Note, the equipment I have is not really featured there any longer, although some old datasheets may be around. Suffice to say, the optical output from the Sonica feeds into the 562V preamp/switcher. There is a proprietary connection between Meridian components (digital). It is the 565 which reports on its processing setup. Without me doing anything it seems to sense an AC-3 setup. For instance, from a music DVD where I have 2 choices - stereo or 5.1, when I switch to 5.1 on the DVD menu itself, the Meridian immediately shows as AC-3. Switching back to Stereo, the AC-3 disappears, and just THX remains. Sound is still good, but there is a difference. Generally with stereo sound - esp from a music dvd - I am better with using one of the other Meridian surround modes - eg Super which uses the centre channel and subwoofer, or ambisonic.
Anyway, getting off the point which is that I'm pretty confident I am getting true AC-3 out reliably from both DVD player and VLC from DVD's which have that (providing that the correct audio track has been selected), via the optical out.
Does that clarify it for you?
Ian
See less See more
I saw the SIIG mentioned in the mac-htpc forums: http://www.mac-htpc.com/ftopict-13.html
The person there claims that it supported DTS for DVD playback. But, I'm still skeptical. I PM'd the guy asking for more info.
Also, I downloaded the manual for the products, and the picture in the manual is totally different than the picture on their WWW site. The manual shows a small device with a USB input, a toslink (optical) output, and an analog output.
See less See more
Ian, yes, completely, thanks for the followup. Sorry for my ignorance. I just wanted to make sure your Meridian was auto-identifying AC-3 in the same way, say, as my HK DPR1001 would identify and lock on to it. tji--if you take a chance on any of these, do report back. If the version of the SIIG that you actually get your hands on has an optical out, but comes with no drivers to insert itself into OS X and Apple DVD player software--like the M-audio products apparently do--I suspect you'll get the same PCM pass through result: when you go into DVD player preferences > disc setup > audio output--you will not have another drop down option to toggle to--you will just have "system sound output." I think the true DD/DTS pass through success people are reporting with M-audio lies in the fact that their drivers allow for another audio output option to show up here in this panel--and when enabled instead of "system sound output"--allows something beside PCM to be read.
That's also why I remain skeptical of the driver-less USB device doublewood/Mark is reporting passes true AC-3 under VLC. I'd like someone else to verify it and detail the exact chain from Mac to receiver including very particular VLC settings--because I can't get VLC to do so with either a mini or a Rev. A 12" Powerbook both running 10.3.8 I'd love it if Mark's device did actually work but I suspect it performs no differently than all these other USB audio devices which meet USB standards and are plug and play--meaning they 1) show up in OS X system preferences as a generic USB audio device, 2) do not show up as an disc audio output option in Apple DVD player or VLC and 3) pass PCM. I'd love to wrong.
See less See more
Macguy--I can't speak to the eyehome device--but I have a 1.2 mini with 1 GB of RAM hooked up via DVI to a Samsung 4663 DLP, which is native 720p. I did not order that mini with built-in Airport, just bluetooth. It's on my home wireless network via the ethernet in of an Airport Express--the Airport Express is configured as a remote base station of an Airport Extreme, which is otherwise sending wireless throughout our condo for our Powerbooks.
That mini has a 600GB (soon to be 1.2TB) external firewire enclosure attached to it, but it can also pull and play with no problem any video_ts file off our Powerbooks (or off other external firewire hard drives if they're connected to our Powerbooks at the time.) These video_ts files are transmitted wireless g part of the journey and then ethernet part of the journey--so standard ethernet is just fine. I'm not able to get AC-3/DD/DTS audio yet, no one with a mini seems to be able to without one of the M-audio devices (see other thread) but I'm making due with PCM stereo processed via Dolby ProLogicII. I also use the digital optical minijack out of the Airport Express sometimes to stream iTunes from a Powerbook when I don't feel like using the mini to do it, say if I'm at the kitchen table and my laptop is open, it's just easier that way. I find iTunes audio passed through the AE/minijack optical to optical in of my HK comparable to the PCM audio passed through the USB device I bought, the Xitel. Very clean, my HK does a good job with it, and with iTunes I tend to use HK's Logic 7 rather than ProLogic.
That doesn't help you with your eyehome decision, and I'd like to read more user reports as it pertains to eyehome and audio, but the way I'm using a mini seems to be the other solution you're considering and surround sound aside, I'm very happy with it. Yes it is extra cabling, but in my setup that's all out of view anyway.
See less See more
Do you mean the analogue headphone jack in the back of the mini?
Can the Mini output Digital PCM?
DD and DTS definitely are supported for systems other than G5 and 17" powerbook. What does seem to be true is that the Apple drivers for USB devices do not support DD and DTS. Thus you need something from a vendor like M-Audio that supplies their own drivers. I'm happy with my G4 powermac as a source for both music and HT. I use a Revolution 7.1 PCI card. However I do think Apple has been inexpliciably short-sighted in lack of better support for multi-channel sound. I'm really surprised that they didn't include this in the Mini. I would have expected to see it in all new machines except maybe iBooks. I'm hoping this means that they intend to support DD/DTS passthrough in the standard Tiger drivers. If they do that, then the cheap devices you tried would work.
1 - 20 of 76 Posts
Status
