sorry i can't i use like 5k and my display is absolutely stable so i can use as much as i want.
i would first check the red color manual is that red 100 %?
Thank you, are you using them in conjunction with DisplayCAL?i1 Display Pro 3 and i1 Pro 2 for creating meter correction matrix for the display.
I use them with DisplayCAL as well as HCFR.Thank you, are you using them in conjunction with DisplayCAL?
Also, are you using madVR Extreme?
If I may kindly ask, why do you use HCFR in addition to DisplayCAL?I use them with DisplayCAL as well as HCFR.
I do use the PC madVR software.
Someone has to send one to the ArgyIICMS developer and I am pretty sure he would add it.Is there any planned Argyllcms support for the i1 Pro 3?
Not really, and some late Pros were already Pluses.Any difference between the i1Display Pro and the i1Display Pro Plus except the latter can accommodate up to 2,000 nits?
Thank you SirMasterNot really, and some late Pros were already Pluses.
This is the info from X-Rite:Thank you SirMaster
Yes.Is there any planned Argyllcms support for the i1 Pro 3?
Your confidence is misplaced. Adding (native) i1Pro3 support is non-trival (6-8 months of full time work), so while having an instrument is necessary, it is not sufficient.Someone has to send one to the ArgyIICMS developer and I am pretty sure he would add it.
Oh wow, I didn't think it would be that much.Your confidence is misplaced. Adding (native) i1Pro3 support is non-trival (6-8 months of full time work), so while having an instrument is necessary, it is not sufficient.
ArgyllCMS V2.2.0 has been released. See if that works for you on the M1. (Let me know if it doesn't!)Does anyone know how I can download the beta for ArgyllCMS? I need it for the MacBook m1 so it can find the displays/monitors when I'm running DisplayCal
Perfect, I'll try using it tonight I have installed it with the DisplayCal and it has fixed the unknown display (with the beta) to the corrected named display so I'm hoping that it will work.ArgyllCMS V2.2.0 has been released. See if that works for you on the M1. (Let me know if it doesn't!)
