1 - 6 of 6 Posts
Discussion Starter #1
I have a few questions regarding the capabilities/possibilities of madVR, using an HTPC.
My equipment/system consists of the following:
JVC RS540/X790R/X7900
OPPO-203
i1 Pro 2
i1 Display Pro OEM
ColourSpace/LightSpace
I want to present a few HDR titles on my system as they are superior to their SDR counterpart.
However, the OPPO is quite useless due to its broken HDR/SDR 'Off (BT.2020)' feature.
I understand madVR is quite nice, but my understanding is quite limited.
A couple of questions to begin with:
1) Does madVR use dynamic tone mapping, converting HDR to SDR?
2) Is it based on frame-by-frame calculations, or scene-by-scene?
3) Does madVR require altering settings depending on the title?
4) Does my projector need custom HDR curves for it to work?
Thank you!
OPPO-203
i1 Pro 2
i1 Display Pro OEM
Thank you!
1. Yes
2. Frame by frame
3. No
4. No
Discussion Starter #5
Where to find screenshots of comparisons between SDR and HDR/SDR tone mapped by madVR?
Discussion Starter #6
This might be daily bread to all you madVR enthusiasts, however I need to ask:
- 1920x800 through 'CRU' in Windows, eliminates masking needs (2.40:1) in the projector?
Projectors have potential internal light reflections when masked, avoiding that would be mint.
Added bonus is having no content overscanning my 2.40:1 screen, Windows scaled accordingly.
Perhaps an odd way of solving it, but this would let me zoom all content electronically in MPC-HC.
No need to adjust projector zoom/shift, small resolution loss for narrow content, convenient though.
Worried 1920x800 would cause a resolution loss for 2.40:1 content, seeing Windows look rather odd.
Screenshot comparison of 1920x1080/800 showed identical histograms and pixel information. (y)
I use different customized .hlsl scripts to fit different aspect ratios to my 2.40:1 screen.
Applied as 'Shaders' in MPC-HC, easily callable, correcting the aspect ratio as desired in an instant.
Any recommendations on how you otherwise would solve it?
Am I overcomplicating things?
I don't have my home theater setup yet, hence all my questions.
1 - 6 of 6 Posts
