1 - 4 of 4 Posts
I installed madVR but it did not start in the system tray like the install guide said it would. So I doubled clicked the madHcCtrl icon in the madVR folder and now its running in the tray.
I then launched MPC-HC and selected output but madVR is ghosted out.
Discussion Starter · #3 ·
Originally Posted by CountryBumkin /forum/post/0
You may need to right click on the Install.bat (or whatever its called) and select "run as adminstrator".
I did that.
Discussion Starter · #4 ·
Found my problem. I accidentally installed the 64bit version of MPC which of course won't recognize the 32 bit madVR.
1 - 4 of 4 Posts
