I don’t think the spider does lumens easily? Seems like you gotta run a whole program.doesn't this ignore screen gain?
he has a spider why not use that?
LIVE: Tech Talk Podcast with Scott Wilkinson, Episode 8 Click here for details.
Especially taking regular measurements for bulb age, it's far easier to use a lux meter. It's not difficult to convert at all. Getting the spyder out, hooking up the USB cable, mounting the spyder in some useful manner or getting a tripod out, installing displaycal running it and going through all the steps is far more work than popping out a hand held meter and getting an instant reading.you just run a software that is supported by the spyder like displaycal do a couple of clicks be done.
unlike a super cheap light meter this one will be kinda accurate because it is doing what it is made for.
What do you get off your screen? Looking for sanity check of my NX7 with I think same screen (I have panamorph).Yes, a pure white image. Test with sensor touching the screen pointing at the lens. You read the lux.
Nits = LUX / 3.14 - does not account for screen gain which you can add back in if you know it.
Most 1.3 gain screens are actually 1.15 or so. For one of those you'd use Nits = (LUX / 3.14) * 1.15
Lumens can be calculated as well but requires screen area.
