What happens when a dealer who sells most of then (say Sharp, Dwin, JVC) prefers one one another?
Does value for the money enter into a dealer's recommendation or preference?
Does a dealer have all these set up under similar situations (screen size, material etc) so you can use your own eyes?
Do you buy one from a dealers who has one brand and sets it up so it looks good to you. If only that dealer had the other and set it up, would you have bought that instead.
Say a dealer can't stand what a Faroudja does to reds. Say a dealer likes the brightness of a JVC or Dwin over a Seleco or Sharp?
Everything is a trade off.
What about some idiot whp posts advice all over a forum defending his particular choice and sounds but isn't at all knowledgeable.
Just remember, whatever you buy today, most like will be a POS a few years later compared to the new stuff.
No. Compare bulb projectors 2 years ago to todays, not even tomorrows!
Should you buy something. Yes, if you want to enjoy what it does now. Live for today.
I still enjoy my 9 inch CRT and I keep modifying it to make it even better.
Would I buy a new one today? No. I would probably by a bulb and plan on replacing it for a better one in about 3 years. After 3 years, it just won't be competitive with cheaper new stuff. Can you really be happy watching a Sony 10 compared to a new Sharp? Can you really be happy comparing a Dwin I to a new Sharp let alone the coming Dwin II.
My old Pioneer Elite 1.66 has lasted about 8 years. It was obsolete about 3 years ago. My new HD Pioneer Elite hopefully will last about 8 years. Who knows how long it will take to become obsolete. I do need it now and will indeed enjoy what it does.
The point of this ramle, even the best choice today, will only stay the best for a very short while. So learn to enjoy what you have. Don't be afraid to buy something because something better and cheaper will be available tomorrow because if you do you will never have that enjoyable HT.
