Good idea and I do that occasionally, only issue is DL DVDs that won't easily fit on a SL RW disc without excessive compression. For those you'd have to either use a filter or a much more expensive DL blank in your computer. Also several of the newer DVDs(especially Disney) won't copy with Shrink and would require a newer paid program.Quote:
Originally Posted by Ken.F /t/940657/magnavox-537-535-533-515-513-2160a-2160-2080-philips-3576-3575/25470#post_24659378
You could try using DVD Shrink to make an image of your DVD and then burn the image to a RW disc. You should be able to dub the RW to the Mag HDD without using any filter.
