Originally Posted by tomwom /forum/post/16893749
I've had my Magnavox for some time now and it has started to freeze up on me, it won't even turn off with the power button. I have to unplug it for a few minutes and then every thing is fine.
Also, the hard drive will spin up once in a while as well, even when the machine is off.
Are these two issues normal for this unit?
I just now ran into a possible explanation for freezing with power on.
Important Note:
There has been at least one person who reported that their DVDR seemed to be constantly in clock-search mode, and we never had any explanation... just maybe a "broke clock."
I just did a an Auto Clock > Manual test that might explain some clock "anomolies" like that one and more.
I decided to see what OTHER channels I might have that had a good time signal (using
The 11:57 Procedure ) besides my rock-solid FOX analog 6 and inconsistent PBS.
I first tried my cableco's "Local Origination" channel, analog 2, on my 2160 cuz it seemed to have s time element in addition to local weather conditions, etc. I thought that might be a good prospect, but it turned into the "DVDR death ray and zombie maker"!
That channel kept the time search going for 15 minutes! I finally got tired of waiting and turned the 2160 off, then after 20 sec or so, turned it back on and noticed the clock was set one day ahead to Jul 31!
I reset the date and time to 11:58, re-set my good FOX analog 6 in Manual box, BUT NOW I COULDN'T TURN THE 2160 OFF!
Tried every button on remote and front of unit and only PLAY/FF/REW/PREVNEXT would work to play a title it selected, but finally had to pull the power cord to get it to shut off.
I tried to duplicate this freezing effect but the unit turned off normally, maybe cuz I didn't let it search that bad local channel as long, or it's just a random occurrence?
To me, this suggests more strongly that an all-channel Auto Clock search *could* (randomly) lead to unusual problems, depending on the type of signals the channel search might run into in a user's particular system.
An
11:57 Procedure and setting the Auto Clock for a Manual, single-channel search is recommended, even if you can't confirm a good time signal on ANY channel... setting Auto Clock ON or Manual extends the power backup time from 30 sec (with Auto Clock OFF) to 2-3 minutes, or more in some instances... like my recent overnight total power loss miraculous preservation!
If using Manual for more backup time only, just make sure you select a "benign" channel like analog FOX or CBS... not PBS, which is notoriously unstable and inaccurate... and
definitely not a local cableco/community channel.
