Status
Not open for further replies.
1 - 3 of 3 Posts
I plan on using a ProGear tablet PC as a touchscreen remote. I am using MainLobby, a Slinke, and Girder. I am using the DCOM protocol as outlined in the Slinke help file. I was able to successfully get this working between my Win 2K (test client) and XP Pro HTPC #1. I now want to do it with my XP Pro HTPC #2 and a Win 98 SE tablet (client).
I cannot get the ProGear to allow me to adjust the Nirvis.SlinkeClient Properties/ Security box, so that I can set it to "custom access permissions". It is now stuck on "use default access permissions" mode. None of the variables that I tried to change will unlock this option. I cannot get a remote session at this point.
Does anyone know how to unlock the choices so that I can set up custom permissions?
hjackson
I assume you downloaded DCOM from MS website as I don't think DCOM came with win98 (that's your OS - right?)
With that said, under the Default Properties tab is Enable Distributed Com checked? (should be)
Default Authentication to None, Default Impersonation Level to Impersonate
Enable remote connection selected on Default Security tab
Under Nirvis Properties, Run app on the following computer (IP address of server with slinke)
The Security tab on mine is also greyed out (can't change).
1 - 3 of 3 Posts
Status
