Have you ever thought, wouldn't it be cool to make something like the RPG Diffusers? I have, especially since the number of them I need would be cost prohibitive. I've thought of how to do it, but I have one sticking point. Maybe someone out there can fill in the blank.
The idea is that you make a box about 2'x2' or however big you want the mold to be. You then take 1"x1" cut to various sizes and fix them to the bottom of the box. You then take the lid of the box and drill a few holes. Place the lid on the box and inject foam into the box. Once finished, remove the lid and remove the foam diffuser. Ok, sounds simple doesn't it? The problem is how to stop the foam from sticking. I know that there are many types of foam out there, but I can' think of any way to stop it from sticking. Any ideas? How would you prevent foam from sticking to would, or what type of foam to use. Preferably it comes in a can and can be sprayed through a hole.
Am I nuts or is this a workable idea?
