Status
Not open for further replies.
1 - 3 of 3 Posts
Hi.
I want to try using port 3 on my Barco 808G, but I'm not sure what the
pinout is on the DB9 plug. I've searched the net, but seem to get many
different ways.
A graphic of the plug would be nice, I always have trouble looking at it
from the right side, and so on.:)
Any advice?
Nicholas
Nich -
Howyadoin'?
You shouldn't be having problems finding this information, but I searched the archives and did a cutnpaste from an old post of mine:
DB9 pin # connected to HD15 pin #
1.........10
2..........6
3..........1
4..........2
5..........3
6..........7
7..........8
8.........13
9.........14
HD15 pins 4, 5, 9, 11, 12 and 15 are not connected.
In case you're not sure, let me save you some potential aggravation in identifying which pin is No. 1 and so on. If you turn either connector
toward yourself and look straight at the rows of pins with the broadest part of the opening at the top, number 1 pin is top row and farthest left....and they read just like sentences on a
page; left to right, top to bottom.
For determining what wire is which at the other end or your SVGA cable, I used a basic multi-meter to see which pin corresponded to each bare wire at the other end. Anything you have for indicating a circuit will work.
Sorry, no graphics. I wrote out a diagram for myself when doing this though.
- Chris
The manual for my bg1209 has following pinout:
1 - Not connected
2 - Ground RGBS
3 - RED
4 - GREEN
5 - BLUE
6 - Ground RGBS
7 - Ground RGBS
8 - h sync
9 - v sync
Is the pin 1 connected?
And what grounds to connect to 2, 6, 7 (what does the manual mean by RGBS)
According to this link www.crtprojectors.co.uk/port_3.jpg , the sync grounds are not connected?
Anyone?
1 - 3 of 3 Posts
Status
