Status
Not open for further replies.
1 - 4 of 4 Posts
I have a dual output video card. One output will drive the TV via dvi. The other will drive a monitor via VGA from across the room. I'd like to use this wallplate VGA connector to run the cable hidden in the walls.
http://www.partsexpress.com/images/302-346m.jpg
The total run is about 25 feet. My question is what do I use for the signal cable and which pins are used in the DB-15 connector? I assume the cable will be something like a triple coax with 2 other solid conductors, but I'm not sure.
 Here is the pinout. You could get a pre-made cable and just cut the existing end off, or even better, unscrew the HD15 from that wall plate and replace it with the pre-made cable's end. There are male-female and female-female extension cables available so you could go from wall plate to wall plate or from your video card directly to the wall plate.
1 - 4 of 4 Posts
Status
