1 - 11 of 11 Posts
Last night for the first time, I couldn't get the DVD to eject using the remote from the Samsung BD-D5500 Home Theater player.
Tried several times, DVD refused to eject. Then tried to using the front panel on DVD player... DVD still wouldn't eject.
I could shut the unit off, but same thing, DVD wouldn't eject.
Finally I turned it off , waited 5 minutes instead of turning it right back on, then it ejected.
My question is when I looked at the manual, all it said to do was what I did, turn it off, then try. That's it.
There was no way to get it out manually, like the other DVD players I've had using a paper clip and pushing it in a small hole to eject the DVD.
So, what am I do do if a DVD won't come out and that might happen someday?
Discussion Starter · #2 ·
Well...Thanks for all the responses!
Originally Posted by jack54  /t/1423622/manual-ejection-of-dvd-from-the-samsung-bd-d5500-home-theater/0_20#post_22288454
Chill, jack54. No responses because it looks like you RTFM and figured it out. Maybe you should research a little further next time before you buy.
Discussion Starter · #4 ·
Originally Posted by Otto Pylot  /t/1423622/manual-ejection-of-dvd-from-the-samsung-bd-d5500-home-theater#post_22293429
A little late for that as I bought it Feb 15th.
Discussion Starter · #5 ·
Originally Posted by jack54  /t/1423622/manual-ejection-of-dvd-from-the-samsung-bd-d5500-home-theater#post_22286873
OK, this post was posted 8/7/12.
C'mon, it is time for some replies. Surely someone has had this problem I listed above.
Apparently not. Maybe you got a lemon. Have you tried calling Samsung or an authorized service center?
Discussion Starter · #7 ·
Originally Posted by Otto Pylot  /t/1423622/manual-ejection-of-dvd-from-the-samsung-bd-d5500-home-theater#post_22545594
Nope as it finally ejected the CD and been playing fine since. I just want to know what to do if it happens again. For an example, if I have a blockbuster CD in it like I did then, I need to get it out before sending the player in for service.
There is a semicircular hole in the bottom of the player. Unplug it from the power and run the wheel inside counterclockwise. This drives the eject mechanism manually similar to the spring-loaded or manual drives that one might be accustomed to having (via the pinhole at the front of many PC players).
Discussion Starter · #9 ·
Originally Posted by lifegoezon  /t/1423622/manual-ejection-of-dvd-from-the-samsung-bd-d5500-home-theater#post_24631876
Don't have this DVD player anymore as i got rid of it because of no replies on that problem. The last post was mine, 18 months ago!
This worked for me mostly
I wasn't sure if this was going to work. I have a very small screwdriver that I used in the semi-circle hole with the unit unplugged. At first, I didn't notice anything has happened. Then, I turned the player right side up and heard it rattling. I shook it and a hard it rattling more. I then used the same small screwdriver to open the front panel and the BluRay disc fell out.
When I say it worked mostly, I mean I was able to get my BluRay disc back but I still can't get the tray to open to put in a BluRay disc to play. I will chalk this experience up to a lesson learned - do not buy refurbished BluRay player in the future. This was the first disc I put into this Samsung BluRay player and it didn't play. Brand new BluRay disc I received in the mail yesterday.
Thanks for the tip about the semi circle hole! That is a keeper!
What a useful tip! I thought I was going to have to take the whole thing apart!
1 - 11 of 11 Posts
