1 - 6 of 6 Posts
Discussion Starter #1
So, this friend of mine has the marantz AV8003+MM8003 which I can pick for not a lot. Does it worth picking it up purely for a 2 channel stereo (or 2.1 at most)? Anyone familiar with the sound quality? My first hesitation for sure is the size..., what other reason to go with a vintage 2 channel pre+amp instead?
Those are some very nice units. You may not need the extra channels but should work great. Quality products!
Premium Member
Those are nice units. I would say go for it, depending on what "not a lot" means. Can you buy an integrated amp for less than the separates?
Discussion Starter #4
He suggested $500 for 2 pieces. I can pick a basic new amp or a nice vintage amp, but this monster is tempting!
Discussion Starter #6
Well, I have the HT, as well as 2 other mucis systems. This will be the 4th system in the house! Oh boy...
Thanks for the help.
That is a an awesome deal! I'd go for it. Maybe later you will want to get a HT going.
1 - 6 of 6 Posts
