Hello everyone. I've been reading this forum for about 10 years, but I didn't feel the need to create an account. Now I do, because I have recently bought this unit and ran into some problems.
I have big issues when trying to play 24/192 files from the network. It plays fine for about 10 seconds, and then stutters. The same file is played back ok when using the usb stick, so it's nothing wrong with the file.
I have a DIY 16TB NAS running Open Media Vault and use DLNA from plex and also have installed a plugin called mini-dlna - same problem with the both of them.
Do you have any ideea what this is about? Other FLAC files play fine, it's just the 24/192
Check for other traffic on the network or programs running on the computers. Upgrading your network and/or computers and/or graphics cards might be appropriate.
Verify that cables are undamaged and connectors are fully seated.
Check error logs for signs of problems with hardware. E.g. high network error rates.
From my personal experience, that symptom (stuttering high bitrate audio) is consistent with (although not necessarily caused by) there being a network bottleneck or interference somewhere in between the location of the audio file and the audio output device. Stutters happen when the bitrate of the audio is higher than the network can sustain, possibly intermittently, causing the buffers in the player device to “run dry”. In my case, it was caused by my WiFi network being saturated. Switching to hard-wired Ethernet solved my problem.
Another possibility is too much CPU or graphics being used on one or more of the devices by other programs. (HDMI audio is processed in modern graphics cards.) Decoding highly compressed video might do it, for example.
Error recovery can also interfere with the smooth flow of data, audio or otherwise, whether the errors are happening on the network, in the file server, or elsewhere.
