Thanks for the original link, I missed your post (or couldn't find it!). That's exactly what I'm looking for. Few questions:hi exm i posted back here a little how am using minethe Ch - centre height
Marantz AV8805 15.2 XLR Pre/Pro Official Thread
Searching for a new processor and have been hearing that the 8805 does not have fully balanced outputs. Can anyone shed some light on this? The outputs of the AV8805 are balanced. Internally the AV8805 is not balanced. Since you specifically used the term outputs, then yes the XLR outputs...www.avsforum.com
definitely finding of benefit as fills a hole above centre speaker... with a real speaker... getting good use with dts-X... neural - X been great for upmixing netflix which has a lot of pcm ... to 7.1.6.... even watched an 81 year old movie the other day only with a pcm track that upmixed very well with auro3d !
the Ch adds height to front stage... even lifts it...
theres a good video below from sound united (with folks from dts and imax)talking through imax enhanced... though a long video...a little bit of time spent talking about the Ch speaker and how see as important.
- It looks like this center height does NOT work with Dolby upmixers, so I would need to use Neural X for 5.1/DD or Atmos sources?
- Can you use Auro surround on other sources like DD, Atmos, DTS (maybe a silly question, just never used it)?
- Are you aware of anyone streaming IMAX Enhanced material?
My setup will look like this
[FHL]FL---[FHC]C--- [FHR]FR
TML----------------------TMR
[RHL]LS-----------------[RHR]RS
SUB1----------------------SUB 2
