1 - 1 of 1 Posts
Okay update, got the dv-7001 last Tuesday , awesome looking machine, Marantz build Qualty. and matches everything , very happy .
Now my ? is is anyone using this as a audio cd palyer ,using the analog 2-channel output only , ? Want to go to SACD soon..
I have this running to the marantz SR-7002 RECV. and its plays nice but on the Recv. I peak out with the Audio ,so I have to add attnuation to it so the peak level goes down , and them the sound gets reduced so much it does'nt sound good,
so I took off the Anaolg cables & went to Digital coax cable , Sounds great and no peak out ,
Now if I hook up the SACD ( 6 channels ) will I get the same peaking out?
Any info would be helpful...
1 - 1 of 1 Posts
