Hello all,
Yesterday I purchased a Marantz nr1403 receiver and I set everything up, no problem. It all seems to be working fine. Today I went to connect my Macbook Air to the AUX HDMI input on the FRONT of the receiver via an HDMI to Mini Display cable. The screen on my macbook flickers as it does when a display is connected but no display appears on the TV. I can plug the macbook into any of the HDMI ports on the back of the receiver and the macbook's display appears on the TV and everything seems to work fine. When I connect other devices, such as a blu-ray player, to the front HDMI AUX port they work fine as well. If I goto Setup Assistant on the receiver and choose Input Setup, there is no AUX input listed, only the ones on the back are listed, cable/sat, game, dvd, etc. No AUX. Does anyone have any helpful information? I called Marantz and they could not help me. They said that all the ports are the same and if it works on other ports, and the port itself is functioning, it should behave the same as all the other ports.
Summary: Macbook air display doesn't appear on TV when connected to AUX HDMI port of Marantz nr1403, but works on other HDMI ports and other HDMI devices work on the AUX port.
