I use Avia to calibrate it, and contrast is a toughie. The right white bar seems to disappear at 60ish and 74ish. Owners, could you please post your settings? Brightness, sharpness, and color all were easy.
Also, for instance when I watch LOTR, the title scene seems grayish in background. However, scenes with the ring etc, make the black bars go black. Is this just contrast playing tricks with my head, or do I have another issue here? It almost seems like the grey scale is changing at intermittant parts.
Finally, I know that brightness mode should be set to off, but is it ok to run the lamp mode on high?
Cheers,
KeithR
Cheers,
KeithR
