1 - 6 of 6 Posts
hi im trying to connect a musical fidelity a5 integrated amp with a HT bypass to use with my sr7005, to power my mains and for listening to music via a sonus and dvd player. i would deeply appreciate it if someone can tell me what connections from the a5 and where to sr7005 i need to make. sorry to be such a newb but want to try this myself.
Discussion Starter · #3 ·
funny thing is the marantz sr7005 now controls the a5 without inputting the a5 code on my harmony 1.... i have my sonus connected to the a5 on tape input or should i have the sonos connected directly to the sr7005
Discussion Starter · #5 ·
thanks i tried it with the sonos connected directly to the a5 and then to the sr7005... the volume level and sq seemed much stronger when the sonos was connected directly to the A5..... didnt have the remote issue when i had the a5 with sonos connected to my old denon 3805..... i believe the remote code for the sr7005 and the A5 are the same, on another note i love this receiver
1 - 6 of 6 Posts
