Marquee squeeze mod instructions, and did we lose a ton of old posts ?
272 Views 2 Replies 2 Participants Last post by  gn2
Hi can someone please post detailed intructions on what to change to get the vertical squeeze mod done to have proper 16:9 aspect ratio with a Marquee ? I've done a search with as general a term as "Marquee" and didn't find it. Nothing came up when I did a Marquee squeeze mod search. Were a ton of valuable posts lost when the server was upgraded ?
Status
Not open for further replies.
1 - 3 of 3 Posts
Guys!
For an 8500 or 9500, locate R704, R804 and R904 on the vertical board, it is the board on the rear heat sink with green/yellow wire pairs plugged in. Replace those three resistors with 56kohm, 1/4 watt, 5% or better, and then match raster heights in the service menu; UTIL, 9, 0901, 3; reconverge if needed.
Thanks Tim, You're the BEST !
1 - 3 of 3 Posts
Status
