  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Marquee technical experts, explain this challenging problem!
263 Views 3 Replies 2 Participants Last post by  cmjohnson
Here's a real challenge for you. Post what you think the problem is.
Projector: Marquee 8000.
Symptom:
Projector in CONVERGENCE mode.
RED raster: All non-center zones move and converge normally.
BLUE raster: All non-center zones move and converge normally.
Attempts to move the RED raster via the CENTER zone move
the BLUE raster INSTEAD. This is only visible after switching to the
BLUE convergence screen.
Attempts to move the BLUE raster via the CENTER zone move
the RED raster INSTEAD. This is only visible after switching to the
RED convergence screen.
The yoke harnesses have been triple checked, removed from their
board sockets,, and reinstalled in their board locations with EXTREME care,
working with only ONE tube and connector at a time. Wherever the listed
color is present on the silk screening of the boards, the connector has
been matched to that color with great care.
The problem continues exactly as described.
Post your best guess.
Problem 2: Crosstalk between channels. Turning up the G2 settings
on any tube with the other tubes shut off results in the shut off tubes
showing a raster, too. This occurs at higher G2 levels than you would
normally use, but I would expec the three channels to be completely
independent. Apparently there is some crosstalk. What's the diagnosis
and cure?
CJ
See less See more
Status
Not open for further replies.
1 - 4 of 4 Posts
Problem one
Switch the red and blue horizontal plugs
Problem 2... what do you mean crosstalk?
Check integrity of the video cables (from input board to neckboard)
I have seen where the wires get kinked or shorted when the you put the convergence hinge up.
Diagnosis on problem 1: Will be checked shortly. Probably correct.
Reason: Center convergence zone does NOT work on the convergence circuit,
but instead works on the horizontal deflection circuits.
Problem 2: By crosstalk I mean, hit COLOR 2 on the remote, shutting down
red and blue guns. Now start cranking up the brightness and contrast on
the green gun and look in the lenses at red and blue. They start to show
an image as well. It gets bright enough to visibly change the color balance
on the screen.
CJ
See less See more
Diagnosis confirmed. Red and blue yoke plugs swapped at the HDM.
As the HDM in this case is the type where the color code is not printed
on the board, it's an easy mistake to make.
You passed. :)
CJ
See less See more
1 - 4 of 4 Posts
Status
