This is probably not a significant issue but I have to ask.
I took off the top cover (bottom cover in my application, actually) on my Maruqee 8000, and I noticed that there's a ground wire hanging loose in the blue CRT section. It's terminated in a ring terminal, but I don't have any clue where it should go to. The connected end is connected to the tube shroud about midway down its length.
Can one of you tell me how many ground wires there should be on the blue tube's shroud assembly and where they should each lead to?
My projector runs just fine. I don't think this is an important issue, but I'd like to tie up this loose wire in any event as I am sure that it COULD short out against some live connection elsewhere. It would be my luck that it would do so.
CJ
CJ
