Status
Not open for further replies.
1 - 2 of 2 Posts
I really have just a quick question and couldn't find the answer with a search. If a person was to swap tubes between 2 working marquees could the coil magnets be left in place and just unpluged from the circuit boards?(thereby eliminating the need to remove and re-align them with exposure to the high-voltages). I have read that on the sony 1XXX the leads are soldered to the boards and cutting and re-splicing is a no-no, are the Marquees the same way? thanks to everyone......
Sir
You would be okay with that unless trying to load M8000 or M8110 tubes into an M8500, which uses different focus and flare magnet yokes.
1 - 2 of 2 Posts
Status
