Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
Hey All,
Big question of the day.
I am about to purchase a Martin Logan center channel. I can get the Cinema i or the Cinema.
The price difference on them is about $500 here in Canada.
Is it worth it to get the i ?
thanks!
Chris
· Registered
it pretty much depends on what speakers you have currently and what you are planning to do in the future. with the 'i' series, ML tweaked the panels and add low voltage input (for custom installs). if you have 'i' series ML, stick with the 'i' series for proper sonic match. if you have the regular series ML, stick to the cinema. if you are planning on upgrading your other ML to the 'i' series, get the cinema i.
1 - 2 of 2 Posts
Status
