1 - 7 of 7 Posts
So once again there is a great speaker deal and of course I want the best home theatre system on a budget.
I currently have a FOCAL Chorus setup with bookshelves.
I have the 806v up front
CC700 center
705v in the rear
and I just ordered a klipsch 12w sub.
it all sounds very good and i love it but I have never heard martin logans and these seem like a great deal.
I'm thinking my focals will sound better but you all are for sure the experts.
ML Motion 12's $300 each
http://www.newegg.com/Product/Produc...82E16882981006
ML Motion 10's $200 each
http://www.newegg.com/Product/Produc...82E16882981007
and then not on sale probably the motion 8 for the center and keep my klipsch sub.
So would the motion 12's up front....the motion 10's in rear and the motion 8 in the center be a better setup then my focals?
thanks !!
CC700 center
705v in the rear
thanks !!
Towers in the front and back?
Discussion Starter · #4 ·
Yea...ill go to a best buy and check them out...they have the magnoila room in there....
I guess I wouldnt need towers in the back but I do know people who have a setup like that and love it.
ill give them a listen but i think these focals will be hard to beat even tho its just a woofer and tweeter in the bookshelf....the motion 12's have tweeter mid and 2 woofers.
CC700 center
705v in the rear
thanks !!
I have the 816V's and CC800. I have listened to all the Motions ( in BB only).
IMO the Focal is much better speaker.
The Motions just sound small compared to Focal.
1 - 7 of 7 Posts
