1 - 1 of 1 Posts
Discussion Starter #1
So I have some Sonace in wall speakers for my LCR. I wanted to keep these speakers and get a pair of speakers as my rear surrounds in my 5.1 set up (bookshelf). What is important to matching the front stage with my surrounds (if necessary at all). The specs on the LCRs are below:
Left/Right:
Tweeter: 3/4" (19mm) silk dome, ferrofluid cooled
Woofer: 6 1/2" (165mm) polypropylene cone with a rubber surround
Frequency Response: 50Hz-20kHz ±3dB
Impedance: 8 ohms nominal; 6 ohms minimum
Power Handling: 5 watts minimum; 100 watts maximum
Sensitivity: 88dB (2.83V/1 meter)
Center:
Tweeter: 1" (25mm) silk dome, ferrofluid cooled
Woofer: Two 6 1/2" (165mm) carbon fiber cones, rubber surrounds
Frequency Response: 43Hz - 20kHz +/- 3dB
Power Handling: 5 watts minimum; 135 watts maximum
Sensitivity 92dB SPL (2.83V / 1 meter)
So of these specs which are the most important to match with my new surrounds.
Another question, currently I have a pair of in-ceiling speaker acting as my rear surrounds in the 5.1 set up (same specs as the LR listed above) they are directly above the main listening area (unfortunately). If I get new side surrounds could the in-ceiling serve as rear surrounds in a 7.1 set up being where they are located? I was under the impression that rear surrounds in a 7.1 had to be behind the listener. thanks in advance.
1 - 1 of 1 Posts
