What's the best way to provide the audio that accompanies the
video signal at 130ft?
I can see a few possibilities, each with their own drawbacks:
1. speaker wire -- requires that the amp be controlled from
the remote location, might have a conflict with watching
two things at once in the different locations depending
on the amp and the setup
2. line level audio -- how far can this go? if the amp/device
only outputs stereo at line level then that's all you get
at the remote location
3. coax digital -- this is probably the best bet, can get 6
channel sound to the remote location and just amplify
it there
4. toslink digital -- the connectors might be tricky and not
sure what the max distance is, but probably less than 130 ft
This was my first post, hope it works.
