Status
Not open for further replies.
1 - 3 of 3 Posts
Hi everyone, nice forum!!
I have a dish receiver in the main room of the house,close to the TV , hooked up with Svid cable. Now i also have a TV in the bedroom hooked up by coax from the rec. also. Picture is not all that hot, would it be better to use the video/sound outs on the rec. and run them to the TV instead? Whats the max cable runs? Its probably a good 50ft away.
Dave
I have pondered the same thing. I had a run of about 30ft from my dvd to projector. I purchased monster audio/video cables to do this. It worked ok. Then when I was at my AV store in milwaukee I looked at their projector and they used quad shielded coax with F to RCA adapters. I would do the same next time. I ended up using a computer cable for the projector xga input.
A good RG6 coax will have a signal loss of approximately 4 to 5 db per 100 feet. Unless you have a weak signal to begin with, you shouldn't have any problem with less than 100 feet.
1 - 3 of 3 Posts
Status
