Hello
I want to get a Global Cache iTach (to be used with iRule software I think).
Since several equipment will require an IR emitter to get the IR signal, I was wondering if there is a maximum length for the wire of the IR emitter?
Extending the standard cable should be easy (I guess, it looks like very basic cable), but I want to maje sure it will work.
Cboengrand
Cboengrand
