McIntosh Labs MX 121 and Manual inputs
1798 Views 2 Replies 2 Participants Last post by  Bruce Bernstein
I just got this. Don't like the Audyssey Setup because center channel output is too low so I'm calibrating it manually. Not so easy.
Do I want HT-EQ On or off
Dynamic EQ-on or off
Dynamic Volume-on or off
LFE = 0
LPF for LFE. I have it set to 120 Hz but can't say why. Crossover set at 60 which is fine.
Can anybody help me. Printed manual is not the best.
Bruce
See less See more
1 - 3 of 3 Posts
Originally Posted by Bruce Bernstein  /t/1417493/mcintosh-labs-mx-121-and-manual-inputs#post_22166453
LFE = 0
Bruce
Did you read the Audyssey SetUp guide in the dedicated thread here?  There are many important issues not addressed by user's manual and low center volume is one of them.
HT-EQ is an optional setting which you can use if you like how it sounds.
Dynamic-EQ is a compensation for playing at lower than reference levels.  It only works if Audyssey is ON.
DynamicVolume is a compression mode for late-night listening,  It only works if Audyssey is ON.
"LFE=0"  ??? Dunno what you mean.
LPF for LFE is correctly set at 120Hz.
Crossover setting should be determined by the measured FR of each speaker.
See less See more
1 - 3 of 3 Posts
