1 - 3 of 3 Posts
Discussion Starter · #1 · (Edited)
For sale: McIntosh MX-150 A/V Control Center. $7000.
Exquisite processor. Includes original box and packaging, remote, manual and RoomPerfect system. System has been updated to all the specifications of the MX-151.
I can't find any damage to the item, terminals look great, a bit dusty in the awkward corners but that's it.
Prefer pickup in San Diego CA, but I will ship (buyer pays shipping - insurance required). If paying by PayPal add 3%.
From the McIntosh web site:
Description:
The very best in music and film presentation - that's what you get with the MX150. Featuring the latest in HDMI technology with full support of 3D video pass-through, you'll see everything current Blu-ray discs™ have to offer. And when you combine the built-in Dolby® TrueHD and DTS-HD Master Audio™ decoding with the RoomPerfect™ room correction technology, which adjusts the audio signal to the specific acoustics of your space, the result is an enveloping audio experience that puts you in the center of the action.
Dual Zone feature allows you to play different media simultaneously in two separate rooms with independent program selection and control. The vast array of digital and analog inputs can be custom labeled for simplified system operation and matched in volume level for a smooth transition between sources. Assignable balance input and outputs, an analog phono section, bass and treble controls and optional processing up to 7.1 multi-channel using Dolby Pro Logic® IIx or DTS Neo:6 all enhance the two channel audio experience of the MX150.
The MX150's unprecedented flexibility allows custom system design and function for every environment. Control options include traditional IR-remote, web based GUI, and interfacing with all third party control systems. Audio options for up to 12 channels, multiple subwoofers, or bi-amping of speaker systems are built in.
RoomPerfect is a registered trademark and the RoomPerfect logo is a trademark of Lyngdorf Audio A/S.
Specifications:
CONNECTIVITY
7.1 Outputs Balanced -1 (6th & 7th Channels Are SBL & SBR)
7.1 Inputs Unbalanced - 1
7.1 Outputs Unbalanced -1 (6th & 7th Channels Are SBL & SBR)
Stereo Inputs Balanced - 2
Stereo Outputs Balanced - 1
Stereo Inputs Unbalanced - 9 (Including Moving Magnet Phono)
Stereo Outputs Unbalanced - 2
Digital Coaxial Input - 4
Digital Optical Input - 4
Digital Optical Output - 0
AES/EBU Balanced Input -1
HDMI Input -5
Advanced HD Audio Processing, 3d Video Pass-Through, Arc
HDMI Output - 1 (Advanced HD Audio Processing, 3d Video Pass-Through, ARC)
Component Input - 5
Component Output - 2
Composite Input - 2
Composite Output - 2
S-Video Input - 2
S-Video Output - 2
Subwoofer 2 Output - 0
Max # Of Audio Channels In Zone A - 12
Additional Zone Outputs - Zone B: Analog Stereo Audio And Component Video
Advanced Connections - Ethernet Web Interface GUI, USB Firmware Update
PROCESSING
Ultra Low Distortion (DSO Bypass) - 0.005%
Dolby Processing - True HD/Digital, EX/Prologic Iix
DTS Processing - HD Master & High Res. Audio/ES/96/24, Discrete & Matrix 6.1, Neo:6
Pure Stereo DSP Bypass Mode - Yes
Video Scaling - None, Transcode Only To HDMI
CONTROL
Third Party Control - RS232, Web IP, IR Input
Tone Controls - Bass And Treble
OSD Overlay On HDMI Output - Yes
Input-Output Format Indicators - 9 In And 9 Out
Control Of McIntosh Sources - Yes, Wired With Data Cables
GENERAL SPECIFICATIONS
Channel Formats - Stereo, 5.1, 7.1, Stereo Subwoofers
DSP Room Correction - RoomPerfect, 1/12 Octave
Microphone And Stand Included - Yes
Network Features - Ethernet Control And Setup
Unique X-Over Frequency, Each Speaker - Yes
Special Features - Up To 121 Input Capability, Front Stereo Bi-Amp + LFE Sub
APPLE COMPATIBILITY
(Compatible With The Following Devices With The Latest Apple OS Installed)
Airplay Connection Or USB Connection - None
AirPlay Connection Only - None
USB Connection Only - None
WEIGHTS & DIMENSIONS
Dimensions (W X H X D) - 17-1/2" (44.45cm) X 7-5/8" (19.37cm) (Including Feet) X 19-1/2" (49.53cm) (Including Front Panel, Knobs, Rear Panel Connections And USB Drive)
Weight - 31 Lbs (14.06 Kg)
Shipping Weight - 55 Lbs (24.95 Kg)
Retail Price $12,500 (prior to July 1, 2013 price increase)
OFFICIAL PRODUCT PAGE:
including product overview, Owners Manual, Connection Diagrams, User and Installer Menu Overviews and more:
FIRMWARE
Current:
System: 2.0_RC_1
SVN revision: 1:2460
SVN build time: 30/03/12 15:42
Front MCU : 0x2105
RP module 1 :8.20.a
RP module 2 :8.20.a
RP module 3 :8.20.a
RP module 4 :8.20.a
Coldfire MCU: 1.10.a
RP Sharc DSP: 1.0.c
Prefer pickup, but I will ship (buyer pays shipping - insurance required). If paying by PayPal add 3%.
Description:
Specifications:
CONNECTIVITY
HDMI Input -5
Component Input - 5
Composite Input - 2
S-Video Input - 2
S-Video Output - 2
PROCESSING
CONTROL
APPLE COMPATIBILITY
FIRMWARE
Current:
System: 2.0_RC_1
Front MCU : 0x2105
RP module 1 :8.20.a
RP module 2 :8.20.a
RP module 3 :8.20.a
RP module 4 :8.20.a
RP Sharc DSP: 1.0.c
You say you prefer local pick up, but don't list your location. Make is easy for your buyers and tell us where you are!
1 - 3 of 3 Posts
