1 - 5 of 5 Posts
hello , I'm looking for surround headset that will work with dts movie and dolby at same time .
I found 2 headset from sony .
Sony MDRDS6500
http://www.amazon.com/dp/B004P15HD0/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=2SSOQAVUT1WL&coliid=IUE3Q0H9L1JL7
can this headset work with dts movie perfectly ?
and another headset is :
Sony MDR-DS7500
http://www.amazon.com/Sony-MDR-DS7500-Wireless-Surround-Headphones/dp/B005LA53D8/ref=sr_1_1?s=electronics&ie=UTF8&qid=1384277308&sr=1-1&keywords=sony+7500
there is a big Different price between them . why 7500 is expensive than 6500 ? all this headset play dts movie .
can I buy 6500 and give me surround sound like 7500 ?
can you suggest another headset that work with dts and Of course surround sound , my maximum budget is 270$ .
sorry for my English :)
Premium Member
The 6500 takes in optical toslink as its only digital source.
This means it cannot decode lossless codecs like Dolby TrueHD and DTS-MA
The 7500 takes in HDMI as its digital audio source.
It can decode lossless formats.
The 6500 is now discontinued by Sony (but still available)
the 7500 will likely soon be discontinued since it has been replaced with a newer model.
Yeah, I just got the MDR-6500 a few days ago from Amazon. It sounds great, but I may return it and import the MDR-HW700DS (which seems like it's going to replace the MDR-DS7500) from Japan.
Did you finally changed the 6500 for the 700DS? I've the 6500 and don't know if change it for the 700ds worths the difference
1 - 5 of 5 Posts
