Ok, I have seen the answer before but failed to find the right topic here or in the theater construction section. What is the normal temperature range on the out of JVC G11 output fans? I have built a hush box. When my fan hsuh box fan did not start G11 turned off at the temperature well above 135F. It is currently operates around 125F. Recommended temperature in the box is to be around 95F. Where? Up above on top of the project? Below by the intake? When the projector upside down (as in my case)?
Vadim
Vadim
