Ive been lurking on here for a while but as I have started finishing my basement, I decided it was about time to get registered on here.
As part of finishing the basement, I have dedicated a 14'7"w x 28'L section for a media room. My goal for the room is not to have an air tight/sound proof 100% dedicated theater but however have a more open floor plan media room where we can watch the Sony HS20 projector while playing pool in the next room for example. To accomplish this, the entry way into the media room measures approximately 8 ft wide.
Anyways to the point... I am just about complete with the framing of the basement and am revisiting my original plans and wanted to get some opinions on how to proceed when it comes to drywall and wall treatments. My original plans included using resilient channel on all wall surfaces with a double layer of drywall and a rigid fiberglass/GOM combo on top of that. I am now thinking that at least the resilient channel is overkill since there is a huge "hole" in the entry way to the to the room for sound to escape the room. My thinking was to Deaden the room somewhat with the double drywall and rigid fiberglass but for the most part, My wife and I dont see sound leak as a too big of an issue. I appreciate any feedback anybody might have. Thanks!
One more thing, I have done searches etc looking for some viewpoints on how to proceed but I have had some issues finding wall treatment ideas on a more informal media room with the large entryway vs a dedicated theater. Thanks Again.
