1 - 1 of 1 Posts
Having a hard time getting the Mediacom Atlas OCAP 5-Device Remote Control to work with my new Vizio 47 inch XVT473SV.
Mediacom Remote
url
Vizio Remote
url
Basically i am able to get the power and volume of the Vizio to work on the Mediacom remote using code 0178. However, I'm not having much luck with any other buttons. I would like to be able to use the Vizio apps button with the Mediacom remote. The apps button on the Vizio remote pulls up the Vizio widget screen and you can use left/right to scroll thru your apps and then select OK to start the app (Netflix, Pandora,etc).
On the Mediacom remote, when i press TV then Menu, I do get the Widget Screen. I can use left/right to scroll thru my apps but when I choose one and select OK, the Mediacom Guide comes up and not the App. I would love to get this to work.
Is there a better code than 0178 to use with Vizio XVT473SV?
Any advice would be greatly appreciated.
1 - 1 of 1 Posts
