What is there not a option for "Two-mono" !!!!!
Why on earth would I not want to use TWO-MONO for 5.0 or 5.1? (rhetorical question)
The cabling would be hideous for me otherwise! To think that you could not send a "two-mono" signal and connect both subwoofers to two 861 XLR analog outputs is absurd! Please tell me that I have misunderstood the sales representative.
The most popular and BENEFICIAL configuration for 5.1 when using two subwoofers, is to have them work TOGETHER! They should handle the LFE channel and/or the summed bass information TOGETHER! This splits the workload evenly between both subwoofers.
I am using five Nautilus 802 speakers and would use a crossover point around 55Hz for both home theater and music. With 5.0 music, both subwoofers would work as a unit!
(side by side in a corner).
Stereo subs makes no sense in a 5.0 or 5.1 movie/music. It is nice that you include that option, however, please tell me that
I don't have to use a bunch of y-cables, when you have extra JACKS on the OA12 cards!!!!! It makes a huge difference to me.
In my case, I would have to make one XLR feed FOUR XLR inputs (2 on each subwoofer). It is reasonable to have a cable split into
2 ends, and use two of these cables. However, I would have to make three Y cables and a custom messy XLR cabling solution...
----- Original Message -----
To: [email protected]
Sent: Monday, November 29, 1999 3:34 PM
Subject: URGENT: 861 with 2 Velodyne HGS-18 subwoofers
Dear Gentlemen,
I am interested in purchasing a Meridian 861, however, I have some 'problems' or at least considerations that need answers.
First of all, I downloaded your 861 configuration utility. My system consists of the following:
Five Nautilus 802 speakers
Five Bryston 7BST monoblocks (XLR)
Two Velodyne HGS-18 subwoofers (L,R XLR inputs on each subwoofer)
Here is one of my problems:
I want to hook up both Velodyne Subwoofers in mono mode. I am VERY upset to think that I would have to use multiple Y-cables to achieve such a configuration.
I was told that I would not be able to plug both subwoofers via XLR to the 861. You can provide stereo subwoofers, but you cannot provide two mono connections? ABSURD!
First of all the HGS-18 reccomend that both the Left and Right XLR input is used, even if mono. I already would have to make
a y-cable for each subwoofer, to connect the single XLR on the 861 to the left and right of the subwoofer. That would have been fine.
But I was told that you cannot support 2 connections to the 861 for 2 mono subs! That makes no sense for 5.0 or 5.1!
I have 5 full range speakers. If I wanted to cross over all five channels at 55 Hz for the Nautilus 802 and sum that with the LFE channel. It only makes sense to use two subwoofers to share the workload! Who and the heck would want stereo subs for 5.0 or 5.1 ???? Please tell me I can hook both subwoofers to the 861 and send them the same mono signal without having to resort to
a mangled mess of XLR y-connectors!!!
Dear Gentlemen,
