I'm a Boxee fan and want to put together an HTPC around Windows. (the Windows build will eventually have Netflix thus the choice of Windows over linux)
Unfortunately this port doesn't support DXVA.
What's the recommended cpu for a system lacking any DXVA acceleration? It needs to be able to decode 1080 mkv's smoothly. There's a sticky on the subforum that suggests an Intel Duo E5200 will work. Is that accurate?
