1 - 1 of 1 Posts
Premium Member
I am selling my MiniDSP 2x4 (unbalanced). I recently upgraded my subwoofers to (4) SI 18 Diy subs and now my subs only need 2 PEQ filters which my UMC-200 can do. This worked wonders when I had two PSA XV-15s.
Shipping and paypal fee included. This sells new with the plugin for $135 and usually takes a 1-2 weeks to receive from Hong Kong. I can ship next day.
The miniDSP 2x4 in a box is a flexible pocket size DSP processor with 2 x analog IN, 4 x analog OUT. Combined with a plug-in software for programming, one can configure the on board Audio processing filters real time from a PC or Mac environment. Once the board configured, the device operates standalone and doesn't require a computer anymore. For more information on potential applications, please check the application section of our website.
Technical Specifications
- 28/56bit DSP Engine
- 24 bit ADC/DAC resolution
- 48kHz sampling rate
- Unbalanced inputs switchable with a jumper between 0.9Vrms and 2Vrms
- Unbalanced outputs: Max 0.9Vrms
- Digital Audio input/outputs via I2S
- Nichicon Muse Audiophile capacitors
- Volume control by potentiometer on 3pin header
- 5pin, 2.54mm pitch header for panel mount USB connector
- Plug&Play USB driver and real time Software configuration using miniDSP plug-ins
- Device does not required a PC once configured
- USB self powered device and wide range of DC power options (4.5 to 24VDC)
1 - 1 of 1 Posts
