Status
Not open for further replies.
1 - 3 of 3 Posts
I'm looking at the Digital Connection site at the specs for the MyHD 120 card.
I'm seeing lots of specs about what it can do, but not much about how fast a PC you need for it to really be able to do all these things.
I like the fact that it uses hardware encoding, so I get the feeling a state of the art monster with 3.2gHz isn't exactly required.
Will I be able to put this card into my existing less than state of the art PC (Athlon 800mHz, 768mB SDRAM, XP Home, no-size-limit-removable-hard-drive-bay), or do I need to upgrade the CPU and maybe the memory first?
Thanks...
Your machine is more than adequate for HD timeshifting (record/playback). Just don't expect to record realtime analog at higher than 320x240 on your configuration. I wouldn't recommend attempting analog capture on the myHD cards at all. Use an ATI TV Wonder VE/Pro for analog cable/OTA recording.
The myHD cards are excellent as HD VCR's. As alternatives to the JVC 30K/40K D-VHS units and HD set top boxes, the myHD cards make a lot of sense.
Don't be intimidated by the seasoned members here or on the anandtech's and extremetech's on the net, with their bleeding edge 3Ghz+ boxes and all the up-to-the-minute frills like SATA and Firewire800. The reality is that it takes months and years for new CPU platforms and I/O standards to mature and stabilize as the bugs are discovered and removed, and driver stability is achieved.
Use what is needed to get the job done- your machine is fine for this purpose. A user in a past thread reported that the myHD worked in his PII 266Mhz box!
My system has a 600 MHz P3, 256MB of RAM, 120 GB ATA 133 HDD, and Windows 2000. It works fine for recording and playing back the transport streams of the MyHD.
1 - 3 of 3 Posts
Status
