I decided to buy this set for a customer after my distributor convinced me to buy it. I did not know much about this company and normally do my research to ensure that my customer is getting the most bang for the buck. After installing it and hooking the outside antenna to the rf input; I noticed that the analog picture had a bunch of horizontal lines floating through the picture. Thank goodness the tv also had an atsc tuner which was able to pick up all digital local channels in the area except 1. The weird problem with the analog channels is that the unit shows you a clear picture when changing channels, but reverts to crap about a second or two after it finally tunes the channel. This is a problem because one main channel that is modulated to a uhf channel is carrying the direct tv signal and the dtv receiver is located in another room. If the problem is not resolved; I will have to move the direct tv receiver or run an additional line to convert the signal to a composite because of a poor tv tuner. I cannot send the set back because of my distributor's policy which is even more frustrating and the reviews I am reading now are mostly poor of this company. Any opinions?
