1 - 5 of 5 Posts
Discussion Starter · #1 · (Edited)
Outlaw LFM-1 EX Subwoofer - Fairfax VA
I'm selling some of the audio equipment I purchased for a home theater that never got built. I'm located in Fairfax, VA. Prefer local pick-up.
Outlaw LFM-1 EX Subwoofer $400. NOW $350 (Pick-up only).
Condition 8.
Under 150 hours of use.
Driver Type: Down Firing, 12" Long-throw Woofer
Ports: Dual
Amplifier Power Rating: 350WRMS
Frequency Response:
(one port plugged)
16Hz. -180Hz. +/- 2 dB
(no ports plugged_
22Hz. -180Hz. +/- 2 dB
Crossover Type: Linkwitz-Reily 4th Order Low Pass Network
Crossover Frequency: 30Hz to 180Hz and Bypass
Phase: 0 to 180 Degrees
SPL: 118dB (subject to placement and room gain)
Dimensions: (HxWxD) 21.5" x 17" x 24 "
Weight: 67 lbs
https://www.outlawaudio.com/products/lfmEX.html
Martin Logan "R" Ceiling Speakers $750 (2 speakers) - SOLD
Condition: 10.
Open box, never used.
Application: In-Ceiling
MSRP (US): $599 each
Frequency Response: 37–25kHz ±3dB
Dispersion: 80° x 80°
Sensitivity: 92 dB/2.83 volts/meter
Nominal Impedance: 4 Ohms. Compatible with 4, 6 or 8 ohm rated amplifiers.
Recommended Amplifier Power: 20-300 watts per channel
Crossover Frequency: 2,600 Hz
High Frequency Transducer: 1" x 1.4" (2.6cm x 3.6cm) Folded Motion Transducer with 5.25" x 1.75" (13.3cm x 4.4cm) diaphragm.
Low Frequency Driver 8" (20.3cm) aluminum cone with cast aluminum basket. Concave dust cap.
Weight 8lbs. (3.63kg) each
Overall Dimensions: 11.5" (29.3cm) Diameter, 6" (15.2cm) Depth
Cut-Out Dimensions: 10.5" (26.7cm) Diameter
Depth Required Behind Wall Surface 5.9" (15cm)
Projection From Wall Surface .125" (.3cm)
https://www.martinlogan.com/architectural/electromotion/specs.php
Mirage OMD-C1 Center Speaker $230. - SOLD
Don't have original box. FedEx can box it for $30. Shipping not included.
Condition 8.
Under 100 hours of use.
System Type:OMNIPOLAR™ Center Channel
Impedance: 6 Ohms Nominal / 4 Ohms Minimum
Weight (Kg/lb): 15 lb / 6.8 kg
High Gloss Black
Tweeter : 1" Pure Titanium Hybrid Dome Tweeter
Midrange: 4" Poly Titanium Deposit Hybrid Midrange Driver
Woofer: Two 5.5" Poly Titanium Deposit Hybrid
Frequency Response(Hz, +/-3dB): 65 Hz - 20 kHz (+/- 3dB)
Room Efficiency: 90 dB
Overall Dimensions (HxWxD): 7.88 x 19.125 x 6.8
Amplifier Power Output: 10-175 Watts (unclipped)
Crossover Point : 1 kHz and 2.7 kHz
http://www.miragespeakers.com/products/om-design/?sku=OMD-C1
Fairfax is a little far for me (Philadelphia area) but will let you know if I'm coming nearby
Sent from my D5803 using Tapatalk
1 - 5 of 5 Posts
