Hi all,
I have a Mitsubishi 55809 that I've been using with my HTPC for a while now. I had my Mits serviced (IC Chips went bad) and when I got it back I plugged in my VGA to 5RGBHV Cables (just the RGB though not the HV cuz I get a buzzing sound when I plug them in now). I had borrowed a TV while mine was away and tried to get my computer working with it so I had selected some other Powerstrip timings but now that I have my Mits back I selected my old Mits AVS timings and my desktop is about 3 to 4 inches from the left side of the screen and the top of the desktop is all squiggly like it is being squished against the top of the screen.
I only use this for viewing DVD's from ZoomPlayer and for watching Edited HD shows that I record. Something is definitely hokey.
Also when I run ZoomPlayer the screen just scrolls like crazy....
Anyone have good timings for NVidia 6600GT and the Mits 55809?
And does anyone know how to fix the desktop being moved to the right too much? I can't seem to get it to move back.
Versions:
Powerstrip: 3.84 Build 640
NVidiia Drivers: 162.18
OS: WinXP SP2
Thanks very much
Lance
Versions:
OS: WinXP SP2
Thanks very much
Lance
