Status
Not open for further replies.
1 - 1 of 1 Posts
just curious if anyone has ever used their vga port on the 65711 with resolutions higher then 640x480? i had this working fine about 2 weeks ago. my green crt had to be replaced and now it will not synch. the resolutions i was using are now distored and i can get nothing higher then 640x480. would changing the crt affect the vga port and the resolutions it can display? this makes no sense to me. seems like all i would have to do is hook the vga cable back up and viola, same as it used to be.
thanks,
mike.
1 - 1 of 1 Posts
Status
