  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Mits DLP SQV and weird buzzing noise
190 Views 1 Reply 2 Participants Last post by  irishrulze
Has anyone figured out a way to access the extra SQV memory banks? Manual says to push number within five seconds after pressing SQV, but my tv immediately changes channels with the present SQV. Anyone figure out where the manual is wrong?
Also, has anyone with a 725 or 525 ever had a weird buzzing sound come out of the tv, even when it's turned off? Had this happen twice, once while the tv was powering down, and later as it sat there off. I plan to isolate cabling down to just power cable in case there's some interference. Or any ideas would be great.
Status
Not open for further replies.
1 - 2 of 2 Posts
You have to set up your SQV first, get your channels you want in there, then it should work fine.
1 - 2 of 2 Posts
Status
